I dropped back into Arc Raiders expecting the usual routine: loot fast, keep moving, try not to get pinned in the open. Then the Shrouded Sky update chatter started getting louder, and it's got that "this is going to change how you play" feel. If you're already sorting your loadout and stash, it's worth thinking about what you'll bring out of raid and what you'll risk losing; even basic planning around
ARC Raiders Items starts to matter more when the weather turns nasty and the AI gets new toys.
Hurricanes Change the Rhythm
The hurricane conditions sound like more than just atmosphere. Low visibility doesn't simply make fights harder; it makes decisions slower. You hesitate, you second-guess sound cues, and you end up staying in a bad spot a heartbeat too long. That's where extraction runs usually go sideways. You'll notice it right away: routes that used to feel safe become risky because you can't read the space ahead, and players start bunching up in weird places. More noise, more panic, more third parties drifting in like sharks.
Firefly Forces You Out of Cover
The Firefly is the kind of threat that punishes the habits most of us rely on. Duck behind cover, heal, reset, re-peek. Not anymore. This thing floats and lobs fire from above, so the "safe" angle you've always trusted can turn into a trap. And it's not some paper-thin drone either; the armor around the front means you can't just spray and pray. You'll want clean shots, timing, and maybe a teammate calling out its position because you won't always see it through wind and debris. If you hear it before you see it, you're already late.
Comet Turns a Push Into a Mess
The Comet feels like it's built to wreck teamwork in the ugliest way. We've dealt with Pop-style rollers that explode, sure, but a seismic boom hits different. It sounds like the goal is to stagger you, split your spacing, and make your squad lose control of the fight for a couple seconds. That's plenty of time for another ARC unit to finish the job, or for an enemy team to swing in while you're still trying to get your aim back. People will try to "just kite it," but in a storm, kiting turns into bumping into walls and tripping over bad angles.
What Smart Players Will Adjust First
Most squads will change tactics in a pretty simple order: keep scanning vertical space, stop treating cover as permanent safety, and leave yourself an exit lane even when you think you've "won" the area. The Shrouded Sky vibe is clearly pushing that high-stress extraction loop, where your plan gets interrupted and you've got to improvise fast. If you're looking to stay ahead of the curve, it's probably time to rethink what you mod, what you carry, and what you're willing to fight for, especially if you're chasing an ARC Raiders Moded Weapon in
U4gm before the storm and these new ARC threats box you in.
