Windows 8.1 Available for Pre-Order
Thu Oct 03 2013, 07:08pm
Christo [PCD] Main Admin Registered Member #1 Joined: Fri Feb 03 2006, 10:48am
News item posted
Windows Vista or XP users will need to purchase Windows 8 first
Not too long ago we mentioned that Windows 8.1 would be landing on October 18. All Windows 8 users will be able to download the update at no cost via the Windows Store on that day. However, if you haven't yet upgraded to Windows 8 you can now pre-order Windows 8.1.
Windows 8.1 brings with it several updates that users should appreciate, including a return of the Start button.
The update will also allow users to boot directly to the desktop, bypassing the “Tiles
Fri Oct 04 2013, 07:12am
Enigma_2k4 Registered Member #265 Joined: Sat Dec 23 2006, 08:59am
Mmmm, interesting. As a Windooze 7 user should I rock the upgrade?
Tue Oct 08 2013, 09:04am
In my personal opinion i would stick to Windows 7 for a while longer.
If you are a gamer and still run or planning to run older games, you might have some compatibility and installation issues.
Have a look here at compatible games for example: GameHouse
Oliver Karstel_ZA
Tue Oct 08 2013, 09:40am
Oliver Karstel_ZA Registered Member #692 Joined: Fri Mar 30 2012, 09:51am
I Agree, windows 7 still does the trick!
