Nope. A data table represents a table from a database. Rows aren't named. Using a field called 'Row Name' could do the trick though.Can you assign Row names to a DataTable?
ScubaSteve
Not sure, I don't use data grids much.Can you assign Row names to a DataGrid?
ScubaSteve
You can manually populate the stuff yourself, and keep the data in your own structuresIs there any other Control that I can use to display Matrix type data?
ScubaSteve
