Enable Admin on any Vista
1 2
Wed May 09 2007, 04:29pm
Siversmith[PCD] Admin Registered Member #7 Joined: Fri Feb 03 2006, 04:29pm
You can do this in any version of Vista. However, caution is the keyword
here and you should not use the built-in administrator account other than on
a temporary basis.
Go to Start and type cmd
In the programs list, right click on CMD and select Run As Administrator.
In the command prompt window, type the following command.
net user administrator /active:yes
(Note the spaces and colon)
Press Enter.
Log off of your user account and you will see the Administrator account on
the Welcome screen. This account will not have a password associated with
it. The first thing you need to do is go into Control Panel / User Accounts
and create a strong password for this account.
Resource : Enable Admin on any Vista
How about that little bit of helpful news!
Wed May 09 2007, 07:10pm
Enigma_2k4 Registered Member #265 Joined: Sat Dec 23 2006, 08:59am
Wow... surprisingly simple! Will it work for XP?
Thu May 10 2007, 06:56am
You don't need to do it for XP.
Thu May 10 2007, 09:15am
Morgue[FLB] Admin Registered Member #59 Joined: Wed Mar 08 2006, 11:21am
Erm. I really can't see the benefit of doing this. It's easy to create Administrator accounts using the graphical user interface
Thu May 10 2007, 05:11pm
Silly! When you are installing an application on vista and it gives you say Error 1308 it means that you don't have admin rights. Now with Vista there is a hidden admin that you will need to unlock. In Vista Business and Ultimate it's easy to fix since all you need to do is go under computer management and go enable the admin account. With Home and below you can't and this is the only way to do it.
Thu May 10 2007, 06:03pm
OK, I don't wanna argue, I'm just gonna go with the flow!
Fri May 11 2007, 10:16am
stasja Registered Member #141 Joined: Fri May 26 2006, 10:50am
What? Morgue don't want to argue? I never thought I would see the day... hehe
Fri May 11 2007, 11:38am
Blame it on my 'flu... I feel like this guy looks...
1178876323 59 FT38138 Bonus Cave Troll
Fri May 11 2007, 04:47pm
What you mean your twin brother?
Sat May 12 2007, 02:58pm
No, he looks like this:
1178974499 59 FT38138 Fire Griffin
For reference, I look like this:
1178974499 59 FT38138 Nameless
1 2
